Old 24th May 2007, 03:29 PM   #1 (permalink)
wealdenengineer
SPF MK2 Fuel system
For you guys without the late modified fuel tanks, here is my solution to the fuel delivery problems on the mark2. All pipework, pumps, filters etc are out of view under the oil cooler panel. The system incorporates a Carter 100gph low pressure pump, feeding to a 3 litre header tank, which then feeds the high pressure pump, two filters and return lines to the main tank.
ID:	20244   Click image for larger version
ID:	20245   Click image for larger version
ID:	20246   Click image for larger version
ID:	20247   Click image for larger version
wealdenengineer is offline   Reply With Quote
