Old 05-26-07, 09:31 PM   #35 (permalink)
Chris Melia's Avatar
GT40: England Suffolk
Rep Power: 24 Chris Melia is a glorious beacon of light
Re: Transaxel Comparision
Hi wanni
So you built your baby transaxle and did not base the design on the requirements for the GT40 as you don't have a monocoque chassis this must be true.
I could loan you mine but unfortunately I am using it at present. If you find one, this is what they look like, then you will see why it is important to use original GT40 bellhousing when mounting the transaxle.
Your cable gear change is not suitably reversed to an original style GT40 gear shift either.
The ZFQ is a true nut and bolt ZF replacement, same GT40 bellhousing, same GT40 clutch, same chassis mounting, same gear shift, same starter motor.
Chris.
ID:	20310  Click image for larger version
ID:	20311  Click image for larger version
Chris Melia is online now   Reply With Quote
