| Re: Cav#131 Hi Jim
We as Auto Futura supplied the kit to Johan. The body was pre-shaped and sprayed. The centre section was attached, and the doors, front and rear clip was opperational. All the other bits are then supplied in boxes, with everything down to the last washer and nut. There is no need for welders, angle grinders or similar. It is a pure assembly project.
We supply the same components my assemblers use to put together a car every two weeks in the factory.
Johan also ordered the engine and gearbox through us, and we have been asked to please install such, which is happening within the week. Once up and running, we do a factory inspection and suspension set-up.
Please shout if I can help with any other questions.
Jean Fourie |
