| Re: What causes heavy steering at racing speeds Ross N,
spot on with the idle description. If you have the workshop manual for the cortina , usually they have wheel alignment data. You could get the KPI from that. You can then work out your installed KPI i.e. say cortina KPI is 7.5º with a static camber of + 0.5º and your camber setting is -3º your KPI is 7.5-0.5+3=10
Jim C has mentioned a figure of 6.5º but does not say if this is a corected figure or what it states in a manual. JIM ???
Russ N,
the mass transfer may be part of the problem
If you cant start the engine--thats what tow cars are for -  ))
__________________ Trevor Booth,
Finished assembling a pile of bits incl, mono, 302W on IDF's,ZF, 15" pin drive BRM. |
