| Re: What causes heavy steering at racing speeds Thanks for those Ideas Trevor, we did set the wheelbase at 95" left and right when the rear suspension was modified.I do have data on rose joint turns versus camber change and I will record more when I do the caster.
I had a feeling the scrub radius would be done like that.
Malcolm if you read Jac Macs post#28 his explanation is better than the way I tried to.
Ross
__________________ RF #025 currently racing
ZF,Motec injection
Lotus Europa S2
De Tomaso Pantera |
