Old 06-20-07, 05:39 PM   #86 (permalink)
Russ Noble's Avatar
Russ Noble
New Zealand
GT40: Building scratc
Re: What causes heavy steering at racing speeds
Jac Mac,
Don't forget that with camber compensating suspension which we have here the top link (mainly) will have pulled on more negative camber, possibly the order of a couple of degrees so the tyre is probably flat on the road. Same effect as you hypothesise, just not so pronounced. BTW Ross has confirmed he has set camber to -4 degrees (Damn can't get the ALT 248 thing to work!) Presumably this is the figure that keeps it working across all the tyre.
I think he's got to get the car set up symetrically before exploring other options.
Russ
Russ Noble is online now   Reply With Quote
