| Re: Disc brakes for C-4 corvette front suspension Bill
Couldn't you just get a plate made up similar to these? These are using radial mount rather than lug mount calipers but you would just have caliper mount holes parallel rather than perpendicular to the hub mount holes.
The mount is bolted to the upright with bolts, nuts, and spacer tube to bring the hub mount holes down to 12mm. |
