Old 06-26-07, 03:13 PM   #5 (permalink)
Russ Noble's Avatar
Russ Noble
New Zealand
GT40: Building scratc
Re: oil through frame?!?!
It was common practice for rear engined single seaters, in the sixties at least, to use the frame rails to transfer coolant to and from a front mounted radiator. There were two drawbacks with that, firstly they added heat to the cockpit area and secondly if a tube got torn in a bad shunt you could get boiling water dumped on you.
It wouldn't surprise me in the least to know Porsche were doing that with oil.
Russ
Russ Noble is online now   Reply With Quote
