| Re: Fuel Pump, Weber-style I might be off the pitch here but I thought it was adviseable to use an in-line pressure regulator with Webers.
Most set-ups I have seen use a separate regulator in conjunction with the pump control to maintain fuel flow and pressure rates to Webers especially when using in-line filters after the pump.
__________________ Cordially, James MKI monocoque. XE' 289 short blocks, C6FE heads, Webers, ZF Graviner Fire Suppression
