Re: ARE dry sumps Russ,
Just had a look on their website- the pan you have is PN 1304 which shows in the photo that there is no provision for bolts at the rear main/front corners along with only 3 scavenge ports.
The pan I believe you ordered with 4 scavenge ports in dedicated areas for each crank throw is PN 1302 and is a much better 'looking' item along with having all the bolt holes. It is listed as being suitable for 302/351 which I assume means they have enough material in the area around the rear main cap to allow it to be machined to suit either configuration.
Jac Mac |
