Old 07-10-07, 08:15 AM   #3 (permalink)
Malcolm's Avatar
Malcolm
Gold Supporter
GT40: GTD
Re: Steering rack query GTD
The problem bolt will be the passenger side rear bolt (on a UK car). The rest are as accessible as before. My only concern with a wedge plate system is that you will need to have a matching wedge under the existing platform so that the nut sits properly. You do not want the nut or the bolt head at an angle to the bracketry. You may also find the steering column shafts do not reach if you start to tilt the rack. Can be overcome but is it worth it for what you are trying to achieve.
My rack is raised by 3/8th inch. The ideal for standard GTD suspension setups was calculated as 7/16th inch. However when I had standard suspension components this 3/8 was fine. You will not get a perfect bump steer solution though as the rack is too long but this trick does help noticeably.
One other thing to do when installing these risers is to make them so that the sideways support is tighter than the standard chassis makes it. If the rack bolts are not properly tight you can possibly see your steering wheel not centering as previously and this can be due to a rack moving in its mounts. Not good.
Malcolm
GTD40, Mazda MAX5 MX5, Porsche 996 C4S
Lotus 51c for sale
Malcolm is online now   Reply With Quote
