Originally Posted by Eric D are you using the C5 uprights? or did you copy the geometry and try to translate it to a different set of components?
either way, the roll center for the corvette is nowhere near where you will want the roll center for a mid engine car (if it is so).
the CG and roll centers along with the roll couple is all wrong for mid engine. If you use the C5 geometry, it will never be right.
cheers
Eric |
Eric,
Would you be kind enough to explain why the C5 geometry is all wrong? Also, what are the guidelines for roll centers for mid-engined cars vs. the C5.
Thank you,
Andy
