Originally Posted by gt40fran Wanni,
you supply me a transaxle and I will supply the big HP...lets see what we can do....seriously....
come on Wanni...0-100-0 ....would be a fun one to try first.
We are already in talks to attempt the FIA record for an electric powered vehicle with the current electric world speed record holder(Pat Rummerfield White Lightning Information )... |
OK Fran,
I supply:
1) A sequential unit, magnesium casted, setted up for 310 Km/h
2) A bell housing
3) A clutch
4) A flywheel
5) A concentric release bearing
6) 2 superchargers with a 2 speed gearbox generating 400 HP
7) 4 Michelin CUP 20"
8) The test driver for the set up
9) The driver for the lap
You supply:
1) An LS7 with the 2 superchargers on it having 750 HP with dry sump
2) Your super lite coupé weighting 850 Kgs and having a center of gravity position about 400 mm with a static distribution 40/60 about and a CV 0,32 max
3) 3 or 4 aerodynamic kits in order to have a down force of 300 Kg in the front and 170-180 Kgs in the rear at 250 Km/h
4) 5 sets of shocks with different set-up
5) 20 sets of springs from 70 to 130 hertz with a jump of 3 hertz between each
6) 5 sets of anti-roll bars from 18 to 26 mm jumping 1,5 mm
7) Internal brake adjustment with carbo ceramic disks
and then we go......
we shall beat the actual lap record which is 7,32 in a consitant way.
The Apollo Gumpert is ready to jump in the game....believe, if it does.....it is for 7,15. It is a real ground rocket.
Let us go???
Ciao
Wanni
