Old 07-25-07, 05:41 PM   #1 (permalink)
p thompson's Avatar
p thompson
Administrator
GT40: None
Question A few questions re RF Build...SVA...
Hi all -
I've been helping a friend with an RF build and have a few questions that I'm sure some of you will know the answer to...
1) - re SVA - we are looking to install some SVA compliant switches, to be replaced with more aesthetically pleasing items afterwards. Do you know if all circuits need to be operational.... i.e. could air-con be excluded? and possibly individual pump circuits..? Also - anyone got a spare/used set for loan or re-sale? (seems daft to buy new for SVA then bin/sell)
2) - I notice in the build manual, there is a timing ring (toothed) shown in one of the pictures. I'm fitting Motec to this car and whilst there is a Bosch pickup mounted on the timing cover, there is no toothed ring fitted to the back of the front pulley/damper assy... Does anyone know if this is a standard Ford Part? - an RF add-on? - or a Motec part? ... I could install a generic item but as the trigger is already there I guess there must be a corresponding wheel available..
3) - The car is fitted with a Smiths Electronic Speedo, no problems there, and I see the Audi box has a speed sensor pickup on the near side (UK) - anyone else using this? any issues to consider? as I see in the build manual a mechanical cable setup is indicated.
4) - What make / model is the donor for the steering rack? - again, for SVA we need to confirm its identity/compliance... Someone suggested it was of MGB origin??
5) - Final one for moment - are accurate wiring diagrams available from anywhere/anyone? I've already come across some 'intriguing' circuits and diagrams will no doubt make for easier fault-finding....
Thanks all -
Great car by the way - and it looks great with the Jenvey 48mm throttle bodies on top (IDA) - I forgot my camera today, but next time i'm there, I'll snap and post...
Thanks all -
regards
Paul Thompson
p thompson is offline   Reply With Quote
