Old 07-26-07, 11:20 AM   #1 (permalink)
daveharris
3 Tenths
GT40: Northern Ca,
Rep Power: 10 daveharris is on a distinguished road
need some help with rear suspension:
I have just installed the rear 1/2 shafts and, with the suspension at "full droop" (chassis is on jack stands, suspension is down as far as it will go) the right side (when looking from rear of car) has an interference in the 1/2 shaft joint at the transaxle when you turn the wheel. the interference is between the 1/2 shaft mount (flange that connnects to the transaxle with 4 bolts) and the universal joint end on the 1/2 shaft keeping the 1/2 shaft from turning. (clear as mud yet?).
the left side does not interfere this way. I can not detect a difference in angle (front to back) on the 1/2 shafts, or any angle (rotational) in the enginie mounting when viewing from the rear.
I've tried to "clearance" the 1/2 shaft mount a little in this area with a grinder, but i don't want to go any more until I hear back from the experts on the forum.
sorry for no pictures with the post - camera took a dump - will need to borrow one later this week and try to post if needed.
so - questions - is this typical (i hope not!) - or have i missed something simple?
thanks in advance for the assistance!
dave
Dave Harris
DRB GT-40 Chassis # 41
daveharris is offline   Reply With Quote
