Old 07-26-07, 04:03 PM   #14 (permalink)
jerry
GT40: Roaring Forties
Rep Power: 6 jerry is on a distinguished road
Re: A few questions re RF Build...SVA...
Hi,
I put mine through the SVA test with the standard door windows in and had no problems. The tester reckoned that as they are not glass, then they dont have to be "safety glass"and therefore dont need to be marked up as such.
The items i had to change/modify for the test were-
1) Remove the knock-on spinners and manufacture and fit hex-nuts.
2) Manufacture and fit device to stop contact with the two end toggle switches.
3) Make and fit pad to cover aliminum on steering wheel.
4) Radius filler caps, door handles and rear lights to 2.5mm.
5) Fit grills to side body vents.
6) Fit fog light.
7) Rotate reversing lights 90 degrees.
8) Fit catalytic converters( i declared engine as brand new).
9) Cover 6mm bolt head on underside of heater.
10) Change handbrake pads to sintered bronze material.
I've used the new RF guys to get a new ignition switch and found them very helpfull and more importantly very resonably priced.
Jerry
RF#99
Freestyle Buggy
Brat
jerry is offline   Reply With Quote
