Thread: New Gt40 build
Old 07-27-07, 09:18 PM   #1 (permalink)
561234's Avatar
561234
GT40: SPF MKI #2214
Rep Power: 9 561234 will become famous soon enough
New Gt40 build
I thought that some would find this interesting, I am building a new CAV GT for one of Roy Sayles customers, it will have a Roush 427IR and a ZF, as the engine is fuel injected and equipped with Roush's serpentine belt system(designed for Superformance cars, AC compressor on the r/s instead of the left) I will have to make some mods to the car and I will post any interesting things I find along the way.
The CAV comes with most items needed for the build, bellhousing, brackets for alt/ac, all cooling lines, exhaust system,the cable shifter etc.
If you are installing a Getrag it also includes a clutch, flywheel and the adapters that I see people searching for on this site.
This car has Wilwood brakes, the wide body kit and custom 17" BRM
with Michlin Pilot Sports.
The Roush motor comes with everything needed, alt, AC comp, flywheel and starter, it has been Dyno run and the fuel injection system programmed.
I will have to source a clutch(McCleod, inc t.o bearing) and a slave cylinder.
I also go thru the car and set up the suspension.
ID:	22338  Click image for larger version
ID:	22340  Click image for larger version
ID:	22341  Click image for larger version
SPF MKI #2214, 65 R model clone, 67 Al Craft Indy Car, 03 SL 500, 02 Lightning
561234 is offline   Reply With Quote
