Old 07-30-07, 06:28 AM   #22 (permalink)
Russ Noble's Avatar
Russ Noble
New Zealand
GT40: Building scratc
Re: Spark plugs: seven tan and one nasty black
Originally Posted by jac mac View Post
Chuck,
If its a stem seal its a relatively simple matter to pull the rocker cover & shaft assy & replace the seal using a KD tool & a piece of nylon rope /cord.
Jac Mac
Dimi/Chuck,
Listen to Jac Mac, he's saying you don't have to pull the head off to do the seal!!
It's common procedure for switched on guys like Jac Mac. He's told you how to do it, if you're unsure and need the gaps filled in I'm sure he'll oblige.
Russ
