| Re: Rf 117 In terms of the changes to spring rate as the suspension (and coil/damper assembly) moves over its travel, this is corrected on some quite simple cars. For instance, the Fraser Clubman, in NZ, has the option of a rocker arm assembly to transfer the front suspension movement to inboard springs where the geometry can be set up to suit, avoiding or minimising the problem.
Dalton |
