I have been so busy trying to finish the car that I have not had time to update the build thread. The car is mostly complete with just the little stuff to sort out. I wanted to share some pictures with those that have been asking and to say thanks to all of you who have been such a huge help on this project. If any of you have any questions, I would be happy to answer them. Here is the run down on the car.
The engine is an aluminum block, 8.7 deck 302 dry sump stroked to 380.
Heads - Yates with titanium valve train, spraybars in the covers
induction- custom 3 piece intake with 48 webers w/ 46mm chokes
rotating assembly - billet crank, crower billet rods, custom diamond pistons, 10.7 to 1 compression
Clutch - Mcloed Magnum Forse 8 inch dual disk with billit aluminum flywheel
ZF transmission
3 fuel tanks (2- 15 gal. 1- 3 gal. swirl pot)
Dual swaybars, dual adjustable shocks
Full roll cage
Tons of other stuff that is top secret!
ZF transmission
Full roll cage
