| Re: 1UZFE for Superlite Coupe - Ideas? RE: The 1UZ's weird hydraulic fan drive.
The easiest way to eliminate that drive is to use the fan bracket from the 2UZ Toyota motor. The 2UZ does not have the hydraulic fan drive, but nearly everything on its front cover interchanges with the 1UZ motor.
The Toyota P/N for that bracket is 16307-0F010, and it can be purchased from a Toyota dealer at discount for around $150, or from eBay (Chinese parts??) for around $120.
Also the 2UZ's water pump is identical to the 1UZ's but costs substantially less than the same Lexus part. Same for the oil pumps. |
