Old 08-27-07, 11:34 PM   #11 (permalink)
Cliffbeer2
2 Tenths
GT40: CAV
Rep Power: 4 Cliffbeer2 is on a distinguished road
Re: More New Upgrades
Looks like a beautiful piece of work Ian. I suspect I'll be calling you and placing an order for front uprights shortly.
Unfortunately, I had a front suspension failure occur while driving modestly down the local freeway here. It was a non-fatal incident, but definitely hairy. To be precise, the upright did not fail, rather, the top two bolts attaching the upright to the ball joint block failed. I believe the two bolts loosened over time allowing the ball joint block to move away from the upright sufficiently to put a sheer force upon the bolt which it couldn't handle. I can only imagine how bad things could have been had this happened on the track at speed.
I encourage anyone who owns an earlier CAV to absolutely check the upright bolts on a regular basis and if they are loose to reapply locktite. To get the car back on the road I ended up using very long 12.9 bolts which thread all the way through the ball joint block and then have a lock nut on the outside (and threadlocked).
Thanks Ian for a super nice upgrade option.
Cliffbeer2 is offline   Reply With Quote
