Old 09-05-07, 02:05 PM   #1 (permalink)
GT40: NY
Rep Power: 0 speed620 is on a distinguished road
CAV GT 40 For Sale
FOR SALE, GT-40 MK-1
CAV Serial Number: 0017, ONE OF THE ORIGINAL CAV'S
LICENSED & REGISTERED IN NEW YORK AS A “1966” (NO EMISSION’S TEST)
Car was assembled & maintained by Bill Andrews, HRE Motorcars Inc.
Outfitted with all requisite safety upgrades
Monocoque chassis, welded stainless steel / roll over and side impact protection
EXTERIOR
Guardsman’s Blue, Painted Le-Mans style (Wimbledon White) stripes
Ford GT sill panel stripes, Static-Cling (removable) meatballs and decals
Length 164.5", Width 70", Height 40.5”, Wheelbase 95", Dry Weight 2,150 lbs.
COCKPIT
Original Blue Ford GT Steering Wheel with custom made billet hub
Fire extinguisher (chrome in cockpit)
Full fire suppression with suppression nozzles throughout
Smiths Instruments gauges (220 MPH)
Hidden air conditioning
Stainless Steel (custom made) screening for: front intakes, grill & rear engine intakes
Adjustable Seats, Pedal Box
DRIVE TRAIN
Ernie Elliott built 347 Stroker (rated @ 480+ HP, 7,500+ RPM’s)
Ceramic coated “Bundle of Snakes” exhaust
Hybrid Getrag (preferred gear ratios) option from Bill Andrews at HRE
WHEELS / TIRES / BRAKES
BRM wheels with Vintage Goodyear 15” rubber
Polished, Color Anodized Knock-Offs (Red, Port Side / Blue, Starboard Side), Safety Wired
Dual circuit, front rear spilt with assistance, tandem master cylinder
11.375" ventilated discs (front), 11.375" ventilated discs (rear)
OTHER DETAILS
Doors & Chassis have Dynamat soundproofing; doors shut solid.
Rack and Pinion, 2.9 turns from lock to lock overall ratio 14:1
(2) 10 gallon fuel safety cells (Sill Mounted) Original style fuel filler caps
Individual electric pumps and filters with dash change over switch
High efficiency, six core front mounted aluminum radiator with twin auxiliary electric fans thermostatically controlled with manual override.
This car was built and maintained with performance and no-compromise quality!
Less than 4,000 miles $87,500.00
For Info & More Pictures:
Call: 516-280-5720 or email ram620@optonline.net
Name:	GT 40_1 [Ad].jpg
ID:	23410  Click image for larger version
Name:	VBM GT-40 set 2 026.jpg
ID:	23411  Click image for larger version
Name:	VBM GT-40 set 2 037.jpg
ID:	23412  Click image for larger version
Name:	VBM GT-40 set 2 043.jpg
ID:	23413  Click image for larger version
Name:	VBM GT-40 set 2 045.jpg
speed620 is offline   Reply With Quote
