Old 09-20-07, 10:33 AM   #8 (permalink)
Big-Foot's Avatar
Big-Foot
Gold Supporter
GT40: RCR40 - #45
Rep Power: 21 Big-Foot has a brilliant futureBig-Foot has a brilliant futureBig-Foot has a brilliant future
Re: Internal balance cranks
Eagle does make an internally balanced crank for SBF applications.
There's one going into my 331. No Mallory metal required - just clean-up balancing for the Bob-Weights that should be in the +/- 5 gram area..
Yes the internally balanced engines do seem to run out better and as most know the Small Block Ford (302 in particular) has had a checkered history with block/main failures. Obviously there are some good alternative aftermarket blocks that will help in this regard.
The only caveat I would have is that there are fewer flywheel / balancer combinations available for the Internally Balanced configurations. Virtually NO balancer available for the short serpentine balancer made for the later Ford Explorer and Mustangs..
Regards - Randy
Big-Foot is online now   Reply With Quote
