| Re: 1UZFE for Superlite Coupe - Ideas? Hi Fran,
Any issues with the GT trans as far as location in the wheelbase with adapter plate? -any sgnificant change for engine location?
what type of angle do you expect to run on the halfshafts at ride height? (both from plan and end view)
And does the axle centerline require a change to the engine mounts to shift the crank input shaft height?
I think its a great 'box, and should be about impossible to break.
Eric |
