| Re: Indicated Uneven Weber Airflow One of the great aspects of this site is the ability to share and occasionally benefit from the situations and difficulties that we all encounter from time to time. I try to learn from them and apply the remedy if the situation or symptom happens to me. Hopefully others some of you feel the same way. Sometimes it is the small things or somthing that has been mis-diagnosed or even over looked that ends up being the cause. Well... my recent problem turned out to be the throat that was actually flowing the higher volume of air. It turned out that the throttle plate in THAT throat was improperly fit and was allowing excess air to bypass it when closed, While the original one in question was actually sealling correctly. (brain cramp) I readjusted the other plate and all seems to be ok now, and I will continue on my journey to find the final jetting package.
Somtimes it's the simple things........................
Thanks to all of you that replied.
Rick |
