Originally Posted by roclery I love the look of the spoiler and agree it will cut a lot of air that would otherwise have 'packed' under the front of the car.
If air flow from the front air intake was not restricted by the radiator, it would seem clear that the nostril area should equal the intake area. Perhaps someone with more experience could chime in here, but I would expect that as the radiator would block some of the airflow the outlet should not be as large as the intake. If it's too big, wouldn't this mean there is a risk of the area behind the radiator becoming an even lower pressure area than it ordinarily is? If so, turbulent air could even come in through the outlets to fill this low pressure area, adversely affecting cooling efficiency, and the amount of stagnant air at the front of the car could increase causing extra drag.
Aerodynamics is way over my head at present but most single seaters you see with front mounted radiators have a front opening considerably smaller than the radiator. There again they don't have flow through the radiator blocked by fans either.
If you think a big oulet would lead to a greater low pressure area behind the radiator then I would have thought that would aid airflow through the radiator and help the cooling, not hinder it.
Just my uneducated $0.02
