| Re: Erratic Tach Veek
Try a good ground as Johnathans mentioned, and also look into a tach filter. This was used on some of the early GM cars with fuel injection to filter out stray pulses that were affecting the tach.
I would bet that your ground is bad or there is a poor connection causing the tach to find ground through one of the other accessories. Another thought is maybe the tach isn't getting enough voltage because of a poor connection, and this will cause crazy readings. I recently had an alternator go bad and just before the car stalled because of the lower voltage the tach and speedo went full scale.
Hope some of this helps
Phil
__________________ Scratch Built Spaceframe, 289, Pin Drives |
