Hi Chris,
the gearbox look's great...
I know, I'm a complicated man, and I do not want do to like others.....
I'm planning to build a 962 replica. (actually i'm making 3D plans on solidworks CAD)
Do you know if the ZFQ can be used upside down ?
is it possible to change the side of the gear selector ?
and last, do you have a 3D model (only external) that i can use to make the integration with the crossmember and the rear suspension??
(in fact, i've made a design from the pdf you post, but it's not accurate)
regards
