| Re: Chassis Rotisserie Yep... it's a great idea Bill. I have done it this way before also. The only concern is stability if you actually roll it around. If you tied to two together with a tube bolted between them, it helps significantly.
Just something to keep in mind. The stripped chassis is so light, that it can easily be flipped by two people. For this build, this is what I did. As I figured once I flipped it, prepped and coated, I would have no reason to flip it again. So just flipped it on the chassis buck. |
