| Re: RCR 33 track test & chassis setup Quote:
Originally Posted by Dlampe The wheel weights should be......
Front left 650 lbs Front Right 589 lbs
Rear left 763 lbs Rear Right 715 lbs
I could not edit my own thread, but here is the corrected numbers. Sorry for the confusion. Jac Mac, I didn't look close enoungh when you pointed out the error.
Russ, sorry to confuse you as well. You don't have to be a mind reader, actually I am glad you aren't. | That's good Dean, I saw you had edited your first post and initially thought those were the corrected figures. I wondered whether you were one of those racers, peculiar to the US, that only turn left.
But at least I suppose that's better than the ones that don't turn at all and only race for a quarter mile
Cheers,
__________________ Russ
Most parts now sourced. Body 80% done. Chassis, rollcage 95% finished. Suspension 70% built. Engine starting to build, and trans in a million pieces. http://www.gt40s.com/forum/gt40-buil...atchbuilt.html
