ZFQ new proposed GT40 transaxle
Status
Not open for further replies.
Hi Guys
although this is a little off thread, there are 3 widths of arches the original cars with wire wheels are 70" across the ones in the photo are 72" across like the CAV and GTD, then there is the Gulf arches that are 78" across.
Chris.
Hi Guys
Chris.
A wide backside is always a good thing...just the way I like it. I will have to opt for the Gulf arch version with the snorkies.
Leonard
Hi Guys
Mike Quaife and I will be at SEMA on Tuesday and Wednesday this week meeting the SPF dealers, will answer e-mail's ect on my return
regards
Chris.
Hi Guys
40 units are in production and should be built by end of January 08 we have continued to test over the last few weeks.
Chris.
Hi Guys
the fist batch of transmissions 30 in total will be ready at the end of March but are all spoken for.
Chris.
Chris can you post some pictures of your transaxle installed in a car? Preferable a SPF GT40. I'm interested in seeing how the shift cables were routed and held in place. I would also like to see some pictures of the bellhousing you make and some info as to what clutch and flywheel I would need. Thanks
Hi Richard
Dennis Olthoff will contact you by email regarding the cable change set up, and will be making his improved version of the SPF shift linkage available to ZFQ customers.
I have asked Martin Gough to look through his photo's to see if he has a photo showing the SPF arrangement that we used on Dennis's car as I managed to miss that detail with my shots.
For bellhousing info go here
http://www.gt40s.com/forum/vendor-m...oposed-new-zfq-zf-ford-chevy-bellhousing.html
Chris.
One showing the cable shift
Some pictures of the fitting and cable arrangement. Hope the pictures are of use.
ZFQ: Actual Shipping Date?
Hi Guys
Chris.
Chris:
Did the transmissions actually get sent or is there another delay? A number of us are hopeful that they're en route.
Thanks!
Kim
Status
