Thread: Rf 117
Old 10-18-07, 11:19 AM   #110 (permalink)
ross nicol's Avatar
ross nicol
Re: Rf 117
Lain
I've weighed my car at 1060kg without my 75kg body in it. I'm hoping to get some weight out of the rear clip and anywhere else I can. So my car is borderline on the weight/wheel size issue. I may have to fit those support bars your car has from the firewall back to rear crossmember, had car on the hoist after motor dramas looking at bearings and there was a fair bow in the chassis. I've finally got my wheel rims on the go so hope to have it sorted by start of next season.The old motor is a bit lacking in the power dept so I'm looking forward to the new stroker.Ill be putting the 4 barrel on it with air cleaner.Found quite a lot of piston to wall clearance in the race motor block, I put that down to the lack of air cleaners on trumpets. I find there is a shortage of elbow room in the car which I've made worse by fitting the anti roll bar adjustor on centre console, so try to leave as much room in this area as you can.What size throttle plates did you end up with?
Ross
RF #025 currently racing
ZF,Motec injection
Lotus Europa S2
De Tomaso Pantera
ross nicol is offline   Reply With Quote
