Old 10-18-07, 10:25 PM   #48 (permalink)
ross nicol's Avatar
ross nicol
Re: Roaring Forties #80 Reborn!!!!
Originally Posted by Russ Noble View Post
Ross and Gregg,
Why not run a smaller bypass so the thermostat can work as intended?
Cheers,
I do have a restrictor in my bypass Russ but it doesn't have a small enough hole hence why I like the tap idea.I have also changed the restrictor a couple of times and each time I have to chop my lovely blue -6 hose.It's a PIA bleeding the air out of the cooling system too so dismantling the bypass hose to alter the restrictor size will be a thing of the past with the tap. Jac Mac have you not taken your pills today? I assume being a fellow countryman and Southlander to boot, that your not directing your cynicism at me.Love your direct style though.
Ross
RF #025 currently racing
ZF,Motec injection
Lotus Europa S2
De Tomaso Pantera
ross nicol is offline   Reply With Quote
