| Re: Roaring Forties #80 Reborn!!!! I would suggest reducing the size of the fittings for the bleeds out of the rear of the heads to around -3 or 3mm per side. These are meant to be 'steam ' vents only and by using the -6 fittings your T/stat will never function as intended . You will also be creating a condition where the front half of each cyl head may run hotter than desired due to lack of coolant flow in that area. Your By-Pass must be configured in a manner that coolant is brought close to the thermostat bulb while in the by-pass mode to enable 'real temp' signal to the T/stat rather than an isolated pocket of coolant that creats unnecessary 'on/off' cycling of the t/stat.
Jac Mac |
