| Re: Lost fuel pressure! Dean,
Do you have a pickup line in the tank with a filter on the end. Could be clogged. If you have used lines off ebay they could have junk in them that has clogged the prefilter. Also there may be debris that is keeping the impeller from working. If the pump ran a while with no fuel in it, it could have dmaged the pump itself???? I would advise pulling the lines and inspecting along with the filters.
__________________ DRB#5
351W/408 DIS TWM F. I. 930 Porsche LSD |
