Old 10-24-07, 02:05 AM   #342 (permalink)
OC_'s Avatar
OC_
Rep Power: 4 OC_ is on a distinguished road
Re: RCR's Next car should be.....
Originally Posted by gt40fran View Post
The Ford GT/Ricardo trans will hold 1000hp....Glenn Miller , heads of the Ford GT transaxle programme and SAE paper writer on the subject told me that the ring and pinion was tested to 1200hp.
If you have a G50 in 1st gear with the tail/shift shaft all the way rearwards , the GT box is actually shorter...BUT...it is massive from tip to stern ..it weighs in at close to 200lbs ...so 40lbs heavier but the perfromance is not in question.
6 SPEED....double and triple syncros...cable shift...and its the only big HP midengine transaxle that has gone through OEM testing in recent years in volume...
I have to have a minumum order of 4 to get a price break but currently have seven on order for Superlite Coupe customers ...so in reality they are not as expensive as you may first think
Seems like you were talking transaxles here. Probably should have quoted this and maybe one of the following replies about the G50 trans. Didn't know quotes were all that necessary. I also didn't mean to drift the conversation.
OC_ is offline   Reply With Quote
