Jonathans RCR 40 Build
I got the breathers from a Marine Supply store. I don't remember where but I don't think you will have troubles finding them. Marine Supply is also a good place to source the fuel filler hoses.
Jim, I plan on running the Dragon in it next year.
Chuck
West Marine, Model 138792, chrome plated brass that fits a 5/8" hose. $10.99. Described as a "thru-hull vent."
Rob
I highly recommend the ones Chuck mentions from Street Rods by Michael. I have them and will use them again.
Ron McCall
That's what I have as well.
Today was the big day. The car moved under its own power for the first time. It took a while to sort the shifter out. I could not get first gear. A bolt for attaching the shifter cable heim joint to the sector shaft was bottoming out against the transaxle before it got to the gate for first gear. Once I cut a few threads off the bolt I was good to go.
Rob
OK Jonathan...so I'll be the first to ask....where's the vid man. We have become quite accustomed to having sound bites and vid ya know..... :D
BTW congrats on the maiden voyage.
Congratulations Jonathan...Pictures /Video.....????
Ron et al....
there's a huge order of axles manufactured and everyone will have access to them ...
I have been sending out one-sie two-sies to have them check fitted with the various transaxle packages being used..
