Old 10-30-07, 05:40 AM   #111 (permalink)
jac mac's Avatar
jac mac
New Zealand
Rep Power: 20 jac mac has much to be proud ofjac mac has much to be proud of
Smile Re: Kiwi scratchbuilt
Russ/Lim,
When you make your pattern up to do the castings, make a clip in insert for the rear main cap half circle so that you can cater for both 351 & 302 versions. That is the only real difference between the two apart from the attach bolts adjacent to the rear main cap, but you should be able to add enough material to cover both types in that area.
Jac Mac
