Hi Chuck, the (main) specs for the 370 are:
- 3.400 4340 Forged steel crankshaft
- 4340 Forged H-beam rods
- JE or Mahle Forged pistons
- Moly file fit rings
- New DART 302 block painted color of your choice
- Dura-bond cam bearings
- T&L custom grind solid roller camshaft
- True double roller timing setup
- Custom gasket set
- Professional products balancer
- Melling high volume oil pump
- Melling oil pump drive shaft
- Melling oil pump pickup
- Hydraulic roller lifter
- Ported Dart Pro 1 or Edelbrock aluminum heads
- Jesel shaft mounted roller rockers
- Comp push rods
- Ported Edelbrock Victor JR manifold
- ARP head bolts
I'm new to all this, but i don't think this is low grade stuff. A 1yr 12,000 warranty is offered, not that that is much use to me in the UK, but it's a sign of their faith in the product.
