| Access Hole for Front Suspension I am considering adding two access holes to get at the front lower control arm bolts. The holes would make removal of the bolts for the lower arms much easier. The holes would be a little over 1 inch to clear a 15/16 socket. The proposed location for the holes is indicated in blue on the attached photo. I would think the corner would have enough strength that the removal of material would not weaken it much. What do the rest of you think? |
