| Re: Roaring Forties 105 Made the gear lever and linkages.
Firstly made the housing and shaft to get it to exit on the driver’s side.
Brackets to mount rose joints then I filled in the gaps.
Made a housing on the back with a sperical bearing to allow for the shaft motion.
I made a rev lock out it is in the form of a bolt action and it worked out well.
The small lever is sprung loaded and allows you to move it either side of the block. |
