| Re: wiring query... Paul / Huw, thanks...
I'd wondered if that was the case as the build manual shows an item (little white rectangular lump) up behind the speedo, anyone have price and availability - local or overseas.
Strangely enough it struck me as odd that manual shows the speedo above the column and the rev counter on the passenger side. Has anyone adopted this format? - I've only ever seen (or at least registered seeing) the tacho above the column.
On another note, I know you can provide a dash dimmer switch from Aus Paul but I was hoping to source locally if poss. I believe you used a Toyota part Huw, can you remember the year and model donor vehicle? Supra I think it was, or does anyone have any other suggestions/solutions - Thanks.
__________________ regards
Paul Thompson
Too Many Hobbies  - Too Little Time |
