| Re: UN 1 linkage Hi Bob,
What does the tag that is on the rear cover, at the 5 o'clock position, have stamped on it?
From what I can see of casting marks on the rear cover, it was cast in either '85 or '83. Its difficult to read.
If it is in fact one of the more desirable axles, you have an ideal setup for a rod type shift linkage set-up, as you seem to have the single cross shaft, shift mechanisim.
Cheers,
Scott
