| Re: 1966 Ford 351 Race Engine With Gurney Weslake Heads Hi, Andrew,
If it is a 67 block it shood have the prefix ''XE'' then 6 numbers, my frend Sean has a mirage one in hes shop i can get the rest of numbers if you need. The place to look is on the block where the starter woold mount, ther is a flat and all numbers and letters are ther. If it starts with C9 (69) or D1(71) or E2 (82) or any number then it will be a normal block, or it coold be a Ford motorsport block which will be 4 bolt main but 1980's, and not special like the mirage one.
Hope this helps.
Cheese n Ham, Boris. |
