Old 11-23-07, 01:20 AM   #5 (permalink)
ross nicol's Avatar
ross nicol
Re: Flywheel Balance Weights
Yep when I went to refit my original motor I couldn't find the counter weight for the flywheel which balanced it to 50oz.Had to remove the crank to balance the assembly all over again.My new motor has an internally balanced crank so the flywheel can be neutral as Jac Mac says.Not to mention that I can refit the same balancer it had before.A much better situation for me as I can change flywheels if needed.
Ross
RF #025 currently racing
ZF,Motec injection
Lotus Europa S2
De Tomaso Pantera
ross nicol is offline   Reply With Quote
