| Re: Question on msd 6-al ignition tach output VDO tachs are not directly compatible with the MSD tach output. You will need a tach adapter to make it work. This one if you are using the magnetic trigger (violet and green wires) MSD Magnetic Pickup Tach Adapters: MSD-8920 - summitracing.com
Or this one if you are using the white wire as the trigger: MSD Factory Ignition Module Tachometer Adapters: MSD-8910 - summitracing.com
__________________ Have fun with your build! - Mark FFR Daytona Coupe RCR Gt40 Mk1 in the garage, and underway! |
