| Re: AC system questions Dean
The evaporator should see about 50 or 60 psi when the system is idle and about 35 or 40 when running so plug one end and hook up a regulator with air pressure and do the old inner tube trick by submerging it in a tub of water...sounds hokey but it works. Diagnosing a leak in the evaporator on the vehicle is really difficult so make sure of its integrity before re-installing it.
Phil
__________________ Scratch Built Spaceframe, 289, Pin Drives |
