| Re: wiring the audi a8 speedo sensor Hi Huw,
The pickup on the Audi box in Chris's RF has 2-pins and is likely to be magnetic, so pin 7 on speedo would be the appropriate input.
The pull up is a requirement for some situations where either an ECU does not pull the input high or a hall effect sensor does not pull high. I don't think you'll need this as you have a magnetic sensor I believe (2-pin?)..
__________________ regards
Paul Thompson
Too Many Hobbies  - Too Little Time |
