| Re: Battery disconnect wiring Steve: Seems like that's the best way to do it. If you ground a ground, you just get a ground. But when you ground a hot wire, you get a dead short. Not good. Standard practice when disconnecting and connecting a battery is remove the ground first and connect it last. I'd like to heard advantages of placing the disconnect in the hot side.
__________________ "History does not entrust the care of freedom to the weak or timid."
- Dwight D. Eisenhower |
